I am a new electrical contractor. Currently, I do residential/commercial service work and I have an account with a small home remodeling contractor. By far and large I charge hourly. If I do give a bid, I do it based off of my hourly rate, material cost, etc..I recently had a meeting with an individual who owns both a remodeling/restoration construction LLC and then he also owns another property management LLC, which has 300+ properties. He is already partnered with two other electrical contractors and is looking for third. He has asked me to fill out an "Electrical Master Price List". It is alot. For some of the items, I already know what I would charge. For others, I am at a loss. Any help would be appreciated. Whether, you can share your price list, unsure if that is ok to ask, I have read people spend years building their lists. Or simply a process on how come up with a price for an item. Or maybe recommend a computer software that could help with this. I have read other posts on here pertinent to what I am asking, but nothing that can help specifically. Thanks in advance for any responses.
Those price sheets leave a lot to be desired.
Some items are too specific, and some are too vague. And some are just too redundant or outdated.
Who installs xenon under cabinet lights? Not me
A 25' home run gets priced exactly the same as a 50' home run.
All those different bath fans?
I generalize when I can, and have price groups.
A plug is a switch is a keyless. One takes slightly longer to install, one costs an extra $2.00 I don't care. If $2.00 is that important, go stand on a street corner with a cardboard sign. Someone will give you two bucks.
I price per opening, which amounts to 1 hour of my "take home" labor. In that opening price, I account for up to $10 for materials. Box, wire, staples, device, plate, connectors, wire nuts, etc. That's what I call a standard opening.
Beyond the $10 for materials, I have upgraded prices for openings, and I round to the nearest $5.00
For instance, a gfci costs $9.00-12.00 more than a duplex receptacle, so it's $10 higher than a standard opening.
A smoke detector costs $12.00-14.00 more than a duplex receptacle, so it's $15 higher than a standard opening
One thing to keep in mind with upgraded openings, is electronics. If you're assuming warranty, and you will, you cannot sell them at cost. I add $40 to upgrade to a $25.00 dimmer
Another thing is the number of openings. I have a minimum threshold for standard pricing. Anything less than 8 openings, I'm adding 40-60%
Then the hidden stuff - demo and repairs. I charge 1/2 opening for demo/repair. And count every opening you see. It may look like you're robbing them when you charge 5 openings to cut a singlw wire that has 4 receptacles and a pull-chain attached, but you'll spend that time re-feeding something you didn't see.
And also, they'll ask you to "move" an outlet, can light, etc. I say NO WAY. That wire isn't long enough, and I can't stretch wire. That openi g gets demo, and then another opening gets added.
Makes my pricing simple,
