ok right now my buisness is just myself my overhead is small im going to work on figuring that out today, i got a job a commercial building theres 5 offices storage rm machine shop lights etc.there suppling all material so as a day rate what would be logical or is there some other way i should look at pricing this thanx
Well, a day rate approach is pretty logical, but anyone will tell you, when someone else is supplying the material, you'll have only problems.
Now, back to the day rate, it's good to have a day rate, but it's never good to tell anyone what it is. Even though you're only supplying labor, give them a lump sum bid for a given scope of work. Unless this job is so vague that you can only do it on a per hour basis, then you will have to divulge your per hour rate, and doing so has no upside, only down.
I never tell people the hourly rate I use to price work, if they knew, their head would explode. All the professional, commercial oriented shops here in Los Angeles are using about $80 - $85 an hour to bid work. The union guys, of course much more.
I charge less, because frankly, I'm worth less. I cannot throw 20 journeymen at a job and wrap it up in 2 days. Those guys can and that's why they make the big bucks, I respect that. I have 2 or 3 semi skilled helpers who will take a 2 day job for a big outfit and drag it out over 2 painful weeks. So I charge less....
Rick
