Here's a few pics from the other day...
Chamuit said:
Right here:roll:
Right where?
Ken(480sparky) I will raise you a litre of French beer to you. Found three white conductor on bottom right 3? breaker.
But will raise the bar here this job was not even inspected and what more with 3? 4W delta the phase conductors were not even marked.
Also three conductor tapped to main lugs.
Merci,Marc
Merci,Marc
I ain't playing cause I just can't read the cards. :mad:
mivey said:
Right+Click.Save Target As...
Then you can play.
I've already trid that. I still only start with an image that's 320x240 pixels. Enlarging it only enlarges the pixels. It's the same as putting my nose to the screen.
You will have to re-sample. If your picture viewer won't do it automatically, use your picture editor to re-sample the image, then you can see what everybody else sees.
You can do this in MS Paint using Stretch & Skew at 5X per stretch.
Windows Picture and Fax Viewer will resample on the fly, just like the Explorer zoom.
Merci,Marc
Take a look at the bottom left breaker, unless my bad eyes deceive me, it's also 3-phase and has only one white conductor on it!
I maintain two radio transmitter sites in small towns. Both have 3-phase 4W delta service (one is even open-delta :mad: ) Both were wired by licensed EC's. Neither site had the high leg identified.
grich said:
In IE7, right-click in the open space to the right of the tabs. Make sure Status Bar is checked. The zoom tool will appear.
Don't bother any more. I don't use IE anyway, and I'm not going to update it just to view 3 pictures. I launched it, and I don't have any 'tabs'.
For the sake of human life and property.. I would RAT this out to the local AHJ asap. These aren't mere technical violations, these are SEVERE.
NO Electrician did that work.
I ran across this Friday . . .
We can't save them all . . .
what a mess
what a mess
i wouldn't call him back, butchered up job, tapping off the main feeders is something i have seen in old homes for years. A sure fire hazard and the open enclosure is just asking for problems.
