frenchelectrican said:Ken(480sparky) I will raise you a litre of French beer to you. Found three white conductor on bottom right 3? breaker.
But will raise the bar here this job was not even inspected and what more with 3? 4W delta the phase conductors were not even marked.
Also three conductor tapped to main lugs.
Merci,Marc
Right+Click.Save Target As...480sparky said:I ain't playing cause I just can't read the cards.![]()
mivey said:Right+Click.Save Target As...
Then you can play.![]()
You will have to re-sample. If your picture viewer won't do it automatically, use your picture editor to re-sample the image, then you can see what everybody else sees.480sparky said:I've already trid that. I still only start with an image that's 320x240 pixels. Enlarging it only enlarges the pixels. It's the same as putting my nose to the screen.
480sparky said:Right where?
Merci,Marc
grich said:In IE7, right-click in the open space to the right of the tabs. Make sure Status Bar is checked. The zoom tool will appear.
I ran across this Friday . . .IMM_Doctor said:For the sake of human life and property.. I would RAT this out to the local AHJ asap. These aren't mere technical violations, these are SEVERE.
NO Electrician did that work.
