peter d
- New England
jrannis said:Wouldnt it be kinda sloppy hanging between the 5' barjoists?
You could route it so it's not sloppy. Anyway, like I said, who's looking at it other than us? Nobody.
jrannis said:I dont know if Im ready for that yet.
How big of a reel would it take to handle 300' of that stuff?
Its very rare here in larger sizes. I cant say that I have ever seen MC cable in size 4/0. #10 is the largest we can get off the shelf.iwire said:It's not as bad as it sounds, the longest single run of 4/0-4 that I was personally involved with was about 250' but it had to be pulled above a suspended ceiling .... and the cable can't drag on the ceiling or it will mess it up. We went along and hung a series of pulleys, pulled the cable then went back to support and remove the pulleys. Pretty much like how the utilities string cable on poles.
It's all in what your used to.
We still do run pipe for some things, but cable of any type is used a lot here in this area.
jrannis said:Its very rare here in larger sizes. I cant say that I have ever seen MC cable in size 4/0. #10 is the largest we can get off the shelf.
iwire said:We looked into using some 500 Kcmil - 4 MC for an installation
JohnJ0906 said:I've pulled that size MC (in AL), and you had better eat your Wheaties that morning!![]()
jrannis said:I just cant believe that could ever be cheaper than pipe and wire at that size.
ItsHot said:Does this mean I can through away all my benders?
Anybody have labor units on 500 mcm Al MC vs EMT and Al wire?
200' run
2- 90s and two junction boxes
Assuming a high ceiling like the Walmart job?
JohnJ0906 said:Impossible to install pipe with 360 deg or less, and didn't want to/couldn't put large J-boxes in the drywall ceilings.
It wasn't a question of cost, there were far too many obstructions for conduit. MC was the way to go.
drbond24 said:We're cranking out 750/4 MC as fast as we can all the time. $$$$$$$$$$$$$$
jrannis said:If you have some pics of big MC installed or even on a roll I would like to see it. For some reason its not used in south florida. Possibly due to the fact that we have very little industrial work.
Dennis Alwon said:I am a resi guy but I am quite impressed with the neatness and organization of the work. Don't know much about the J man License so others will have to help.
Looks like you may be the guy that started wiring with romex and then learned pipe. Is this your work? :grin:
