Situation:
Ball Field Lighting
Main breaker and branch breakers are suffering a "melt down".
200 amp LoadCenters (UGH !). 60 amp branch breakers.
Highest load on the panel at any time is 153 amps. Highest load on the branch breakers is 35 amps.
No obvious signs of loose connections, wiring is all compliant.
My first inclination is that by using the load-center we are asking a boy to do a man's job
I can understand to some degree the failure over time of the 200 amp main
(they are the 'tandem" type breakers...look like 2dp molded together). But I have no idea as to why the branch breakers are suffering. Buss is clean, no loose connections.
As far as the branch breakers, would HID rated breakers hold up any better ?
Input welcomed !
Ball Field Lighting
Input welcomed !
