jhardy13
- Joplin Missouri
- Industrial Engineering student
I will happily share what the cause of this is once I've tracked it down. As for pulling the meter, we tried that and we were still seeing small current on the neutral. It was fluctuating between 0.3-3.0 amps with the meter pulled. Whatever the cause is, its most likely on POCO's side of things. I fully intend to get to the bottom of this. Hopefully early next week I'll have some answers.120 watts on the neutral when no power is applied what so ever, can you pull the meter to see if that 1 amp goes away, maybe there is leakage somewhere on the line side of the meter ... either way I'd have a lot of fun trying all the tricks of troubleshooting I learned from the past, you certainly need to tell us what the culprit is when discovered.
