High Frequency Noise/"Dirty Electricity"
160822-2007 EDT
Using a many turn calibrated coil with a calibration constant of 20*f/60 millivolts/Gauss and assuming only 60 Hz magnetic fields, then I generally read about 1 to 2 milligauss for my residual field intensity. The 60 Hz field could be lower if the field has high frequency components. My resolution is 0.5 milligauss.
I just can't resist.......
In 2005 MIT did a study on the usefulness of tin foil helmets with regards to minimizing or eliminating intrusive/mid controlling radio transmissions. It was determined that frequencies that were restricted for use by the government actually amplified or focused the offending transmissions. So, if you are going to wear a tin foil hat, you will almost certainly become a "tool of the government and industry too" (Frank Zappa, I'm the slime). A link to the study can be found below, you have all been officially warned. I think we can also assume that since I have posted this I will be scooped up by the government or perhaps even aliens so I may not be able to post for some time. Please remember me fondly!!
http://web.archive.org/web/20100708230258/http://people.csail.mit.edu/rahimi/helmet/
.....and don't even get me started about the chem-trails produced by aircraft to enhance the effects of the aforementioned mind controlling radio emmisions.
Then there is this:
HAARP Facility to Reopen in 2017 under New Ownership
