zog
- Charlotte, NC
My building has HPS outdoor security lights and we keep having bulbs go out, lucky if they last a year. Is that normal and if not any suggestions?
Some of the bulbs we are using are out of old HPS lights we removed when we upgraded our warehouse lighting so that is likely a factor, but the smaller bulbs were replaced last year with new ones so that makes me suspect somehitng else is going on.
This. 208, 240v and 277v are not the same. If the ballast was replaced sometime and it was tapped wrong, that fixture is likely to have chronic issues with killing lamps early or dropping out before they should due to inadequate supply voltage from feeding 208 into 240v tap. Upper limit of 208v service and lower limit of 240v service are pretty close and lower bound of 277v can get close to upper limit of 240v. So sometimes people unfamiliar with the specific facility make wrong assumptions and hook it up wrong.No that is not normal. They should be lasting about five years.
Bad wiring, ballast not matched with lamp are most likely causes.
Isn't going from light to dark kind of a color change that indicates end of life has passed?:lol:Next time sodium vapor lamps which indicate their end of life by a color change may be tried.
Part#'s on bulbs and ballasts are per label inside fixture.
Always make sure that ANSI rating on the lamps and the ballasts match.
I believe Zog has.
He said per label in the fixture, however you must look at the actual ballast because it may have been changed to something other than what is on the label.
Thanks everyone. There are about 20 lights. I have some things to check but i think the voltage dip may be the key. We do a lot of high current testing on breakers in our shop and that will drop the voltage in the whole building.
Are the lights in question even running when most of this testing is taking place? I can see it being more common at this time of year with shorter daylight hours.
Not much of relevance here.:happyno:Isn't going from light to dark kind of a color change that indicates end of life has passed?:lol:
And, it was.That was supposed to be funny.
