....Almost 50,000 volts from automotive ignition systems (many times)....
If it was the flash capacitor, it wasn't 12v, it was 300-400v.Only 120 for me, aside from 12V DC and a capacitor in a digital camera I was attempting to fix....that one hurt way more than I thought it would!
I will never attempt to repair a small electronic device again, taking it apart was maddening........then came re-assembly....
Didn't anyone check the wiring after he was done?I had an apprentice wire a 480V welding power supply that was on a dirt floor in a steel mill. About a foot away was a steel bollard that was installed to protect fork lifts from hitting a nearby time clock. At quitting time, employees would congregate by the clock and this bollard made a great leaning post.....Until I extended my arm and touched the top of the steel welder casing for a casual after work stretch...The apprentice who wired the power supply had landed one of the phases to the ground lug... up all of my fingertips on the left hand, up the arm----across my chest and then down my other arm and exiting through my other fingertips to the grounded bollard....That one left a mark...
so you touched 2 of the lines? Or did you just touch one of the lines and maybe only get 277.480 off of a motor starter hurt too
When I was around 7 or 8 I stuck a bobby pin into a receptacle and it shot out of my hand and buried itself into the carpet. I couldn't tell if I was shaking my hand or my hand was shaking me. Pretty blue sparks had me intrigued![]()
65,000 volts!![]()
Then there is always that perceived "tendon bind" zap waiting to strike... Tough to get the brain to overcome this one. I've involuntarily thrown a couple tools experiencing it.
