How big of a hole is actually being made? An electrical inspector usually will not question this practice, unless somebody :ashamed1: appears to be "pushing the envelope." I had an older model Greenlee punch and I can tell you - this thing made holes that were WAY too big. One would literally have to nail plate the steel studs because the 1-1/4 clearance might not have been maintained.
BTW - All I'm hearing is "load bearing" wall and nothing else matters. This is not true. Walls can be smoke partitions and not be load bearing. Walls can be fire-rated walls and not be load bearing, and will usually extend up to a roof deck. A "standard fire wall" more often than not is a non-load bearing wall, so don't be so quick to call the guy's boss!
