Ass't Lord-High Commish
True Power Metering
True Power Metering
1) When the voltage and current peak at different times, less than the full voltage times the full current is measured.
2) Added: Besides, PF improvement is not a one-size-fits-all kind of thing. The amount of correction needed must be determined. You don't want to over-compensate for when reactive loads are turned off.[/QUOTE]
1) So, what you're saying is that because the voltage and amperage occur at different points in time, the meter's 'motor' is driven at a rate referenced to the conjunction of their indidvidual sine waves by the real power consumed (delta) rather than the peak values of voltage and amperage? Makes sense... if that's how they work...so what is done in a commercial metering situation to measure peak power usage and PF?
2) Yes, I saw that immediately; and so have felt that devices currently being offered were, at best, quite imperfect. Consequently; being the son of a consummate tinkerer, I began 'pondering' what components would be required to create a dynamic compensatory response to motor-load effects on PF. Turns out the Chinese have a device designed for industrial apps that does just that. Ironically, the same manufacturer sells the 'Power Save 1200' which is a fixed capacitance unit designed for US markets!
True Power Metering
