Posting in here again because i just got the hot tub delivered to me and opened it up to check the nameplate .... 40amp max ... Ive hooked up a few hot tubs before and i have never seen a 40 amp one. Anyone ever seen this? ... because 40 amp disconnects are nonexistent around me without an expensive special order. Even the 2 poll 40 amp GFCI breakers are very expensive and i still have to order them because no one around me has them. on top of that I think i am going to have to use a small outside panel (2-4 slots) as my disconnect because they only have 50/60 amp disco's here. Any of this odd to anyone else?
Edit 1. Added a namplate pic for referrence
Edit 2. IS it possible that this unit for whatever reason is considered continuous load and it was NOT included in the nameplate? ... If that were the case a normal 50amp disconnect would make sense.
