Hey guys, I'm hooking up an outdoor Hot Tub and I'm a little confused after reading the code over and over.
The plate says use a 50amp circuit breaker and 50amp rated wires.
Questions:
1) Should I consider this hot tub as a continuous load? If so, is that 50amps already taking continuous load into consideration?
2) I'm going to run from a GFCI breaker to an emergency shut off switch, then to the hot tub. Do I need a service receptacle within 25 feet?
3) Do I need to run pvc in the ground or can I just use direct burial?
4) What about Bonding and Grounding. Do I need to Bond anything on the hot tub or can i just wire the equipment grounding conductor to the grounding terminal on the hot tub and be done with it? If bonding is necessary, what's the best way to do it? Seperate grounding conductor or use the same equipment grounding conductor?
Thanks guys.
Questions:
Thanks guys.
