And sometimes it does come in handy to know. Last one I did was a half sized tank fed from a boiler domestic water coil. Didn't use the heater elements. Used the tank heater thermostats to run a circ pump in a return line to keep the tank hot. Was pretty common in areas where boilers and domestic coils are common.
Although not so common any more. Newer mixing valves do a good job keeping the temperature even.
Yeah, I DIY my own plumbing as well.
ice
Would be a plus to know a little about control wiring to do what you described above or to trouble shoot why your water heater is not working, but, should be unnecessary to know to be able to size a circuit to a water heater.
JAP>
