Hey all, looking for some input on some weird things going on at my house. I am an electrical contractor/owner by trade, and was in the field for 15 years prior. I think I am pretty good at troubleshooting but some of the stuff going on at my house have me stumped.
Basics:
I need to confirm feeder size, but would an undersized feeder be causing all these issues? For the distance, I think it should be around 250-300mcm. In real world, I don't think I am ever drawing over 100a when these issues arise (dryer, oven, etc).
There's no water ground because there's no water service. Not sure if there's a ground at the meter, I need to confirm. There's no ground next to the meter (it's now in a mud room), but there may be one in the meter. I thought there was a ground wire in the panel , but now that I am thinking about it, it could have been for one of the other sub panels.
MOST of these issues presented themselves after changing to LED lamps. This makes me think maybe there's a polarity issue somewhere. 98% of the fixtures have been changed in the house. Some of them were wired backwards. After re-wiring, it fixed most of the issues, but some still persist.
Tonight I'll check incoming conductor size and see if I can figure out the grounding. In the mean time, is there something obvious I am missing?
Basics:
- House built in 1979
- House has 200A Service
- Whole house generator (20kw), service feeds through transfer switch. All connections are tight.
- Service Feeder is approx 325' ( I need to confirm wire size)
- Most of the house is on Lutron Radio Ra3 and LED lamps. If LED lamps are used, I set to reverse phase.
- We moved in a little over a year ago and I have rewired 80% of the house.
- Wiring is in conduit system.
- Some lights flicker/dim when the Washing machine runs. They dim with every rotation of the tub/agitator. The can lights seem OK for the most part (Soraa lamps), but the Chandelier and Island pendants are affect (screw in lamps). The entire kitchen lighting is on a dedicated circuit.
- All lights dim when the well pump kicks on. Not sure if this is normal, I've never had a well pump before. 15/2 circuit.
- Get a slight flicker in kitchen cans when they are dimmed low and dryer is running (240v).
- Lights would dim when AC's would go on. I put on Soft Starts and that pretty much eliminated that issue. Haven't ran AC since Octoberish so I am not positive now since it's been 4 months and some of the flickering was cause by other issues.
- Some areas I haven't rewired yet, the lights flicker or dim down/up.
- I noticed most of the issues in the kitchen when we are there for dinner. Sometimes oven is on (electric) but I don't think that's the problem since it also happens when the oven is off. I have the whole kitchen on a 70a or 80a subpanel since I ran out of space in main panel.
- Undercabinet lights would dim if there were loads on the same phase elsewhere in the house. This was pretty much fixed by running a dedicated lighting circuit. It seemed to dim on 1 phase more than another, so I moved to another phase. The house is pretty balanced this so makes no sense to me.
