chevyx92
- VA BCH, VA
Existing setup on paint booth. Exhaust fan in paint booth is controlled by a start/stop which controls one side of the coil(208v) of a 3 phase starter, this starter then feeds the exhaust fan. This starter and controller is located outside the booth on the wall behind it. Here's what needs to happen. Install door switches with NO contacts wired in series on all doors of paint booth so that if the paint booth door opens it shuts off the exhaust fan. Sounds simple right. Well I have installed the door switches and placed them in series with one side of the 208V coil. Problem is doors need to be closed before you can push the start button, once you turn it on and then walk back over to the paint booth, open the door to enter, fan shuts down. And they don't want "JUST" the door switches to operate the fan. They want the option of start stop. How can this be done without installing a start/stop in the booth? (if you can even do that legally) Sorry if this is a bit long.
