alfiesauce
could they get away with the 10 second delay like I was mentioning? Or does it need to be an isntant off?
each time the momentary is pushed, it goes from on to off, etc.
The issue with Dougs is that as soon as the door closes again then the fan starts up again, which the way I'm reading it is not supposed to happen.
What about a time off delay timer (I think off delay - time starts on break and then maintains contact until X amount of seconds) on the doors?
This setup would allow them to start the motor with their start/stop station, the fan would start up, they could walk in as normal and the system would still run smoothly with proper airflow. If someone proped the door open or if it didn't close correclty, after 10 seconds the fan would shut down and then the system would have to be restarted from the start/stop station again.
I was rereading original post - if the door contacts are Open when the door is closed then you would need to do a "time starts on make" instead of time starts on break...
I would verify that the setup I'm suggesting is legal as far as safety code goes.
Yes, but you have to 'push' the momentary in the other direction (like down for off, and up for on). The relay Im thinking of itself has 3 wires from it. One wire is the common the other 1 is either for the on, the other is for the off. Im thinking he can have the 'off' parrelled from a 'sensor' switch from the door when it opens. this way it only has the ability to turn it off' when opened.
The other 'switch' on the inside of the booth would be parralled off of both the 'on' and 'off' wires from the relay. So when they are inside they can turn it on/off whenever they want.
This is most inexpensive way that I can think of to do this. Shouldnt cost much. I can see this working, wish I was savvy enuff to put a picture up. Im gonna have to learn how to do that.![]()
You're describing a latching relay. Temporary energizing in either direction.The relay Im thinking of itself has 3 wires from it. One wire is the common the other 1 is either for the on, the other is for the off.
So far, this sounds best. Low-voltage only in the booth, but there could still be contact arcing.The other 'switch' on the inside of the booth would be parralled off of both the 'on' and 'off' wires from the relay. So when they are inside they can turn it on/off whenever they want.
Yes we could do this but short of doing it we want to make sure everything is understood before we start buying explosionproof devices. I can make this work if I add A switch in the booth. The concept was to take the existing setup and make it work. I dont think I can without a delay timer. Thats seems to be the consesus.
Ok, I thought maybe it was more, perhaps not.Why would an air handler require an E-Stop?
Absolutely. Micro PLCs dont cost much, are quick and easy to program, and solve problems just like this one. And when you discover it doesn't work the way the customer actually wanted (even though it does exactly what the customer asked for), its easy to change.Install a PLC
