tonype
- New Jersey
In NJ that SE cable would be fine. PSE&G usually want 3' of separation from the gas and electrical meter.
PSE&G wouldn't allow that cable.
Check out their diagram on 10-2 of the 2014 revision. This is the text from 10-3: "M. Where exposed cable is used, entry into building shall be 6 in. above grade."
You might be correct but I can't see in that photo that the entrance into the house is less than 6" above grade.
I thought this was an NEC thread.....:angel:
"Cable just about comes into contact with ground at the far end (near the lattice) before entering home."
On a bit of a different note, I always figured that PSE&G wrote it that way because (as in the diagram) the entry into the house is the lowest point in the vertical run down from the meter. I figured that they didn't want any part of the un-fused cable being 6" or closer to the ground, not just the entry point. Just an assumption.
Interesting since I did not see NJ in the Title or in the original post...All I saw was an NEC Question post....No. This is an NJ thread.
You mad?Interesting since I did not see NJ in the Title or in the original post...All I saw was an NEC Question post....:jawdrop:lol
The NJ Rehab Code allows the installation of the new panel behind the pipe if the old one was there. But I am not sure if the Rehab Code was in effect in 1990, I was only 11 at the time so I didn't keep up with codes :lol:
Thanks.The Rehab Code was adopted 1/5/98.
LOL...Nope......You mad?
Well, there is some driving force behind your last 3 unnecessary posts. At the beginning I thought you were just trying to be a hall monitor. Now it seems as if your goal is to insult people based on the area they live in.LOL...Nope......
Anytime I think of New Jersey it brings me to extreme laughter...no way I could be mad:lol:
