hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
Question that just occurred to me- this fryer is brand new out of the box? Not used?
-Hal
-Hal
Maybe the first occurrence is a typo and the rest are cut and paste of that typo.
You guys!Good thinking.
Auto fill function could be another culprit.
Possible.1750W=14.58A @ 120V. Easy to see how a typo made that 4.5.
No need.Then one got cut off. Even the 208/240V version has two power cords. Look again! Was this a display model? They usually cut power cords off of those.
You guys!
Brand new.Question that just occurred to me- this fryer is brand new out of the box? Not used?
I wasn't annoyed. just funnin'.What? I think there is a mistake in the info sheet
Can you call the maker and check?
Not going to bother, now that I've supplied it with two circuits.
Not only that, but it says 14.5a per. Thank you.I'm sorry I'm late to the discussion, because the maker's web site specifies two (2) dedicated circuits, one for each power cord.
https://www.admiralcraft.com/equipment/countertop-electric/fryers/double-tank-fryer-120v-6l.html
Turns out it does have two cords. One was opened, the other still bound in plastic.
I am working in a small commercial kitchen, and came across these specs:
Adcraft DF-6L/2 counter-top electric double deep fryer, 120 V/60 Hz/1 ph, 4.5 A, 3500 W, NEMA 5-15 plug
And repeated: 120v/60/1-ph, 4.5 amps, 1750 watts (per tank), NEMA 5-15P
I've seen the power cord. It is a 120v 15a plug, and the cord is not very heavy.
I don't get it. :? The current should be 29.167a.
https://d3ld6frh4bdurh.cloudfront.net/pdf/122-DF6L2.pdf
Another one of life's mysteries solved! Whew!Not only that, but it says 14.5a per. Thank you.
if you use lard instead of canola oil, the power factor goes to hell.
What a sensible question! Even better would be to put your doubts in writing. That way they should get a response in writing.What? I think there is a mistake in the info sheet
Near the bottom:
"Each unit requires a 15 amp circuit"
Cada unidad debe ser concentada a
un circuito spearado de 15 am
I looked at the unit itself Monday, and the customer confirmed it last might. This is a double unit, and it has only one power cord.
Even then, the math doesn't work out. 1750w @ 4.5a @ 120v.
at 14.58A each tank requires a dedicated 20A circuit.
14.58A is less than 15A. A dedicated 15A circuit would be fine.
