How many 12/2 cables…
3 x 3 rows of 12-2 and 4 x 3 rows of 14-2?
The average install with several cables in a large connector is usually pretty random placement vs uniform spacing/alignment.
Yeah it’s based on how the cables land naturally coming down from the ceiling or whatever. You’d have to run them that way from the beginning to ensure they go in clean and in that particular order.
This connector is not a screw type so doesn't just apply even pressure across the cables. It has a wedge with a V notch that push the cables into the center of the connector.
I have used the original 1/2" size of this connector (T&B 3201) for 40 years.
Bridgeport makes a connector that works well for bringing NM into the back of a trailer panel I believe its called a 630-nm
