tallgirl
- Glendale, WI
- Controls Systems firmware engineer
kingpb said:I would still use the 180VA per duplex receptacle, unless directed to do otherwise, and keep the lights separate from the recpetacle outlets. I understand that it is over the minimum required by NEC, but I am old school.
IMO, the Code is deficient in this area because of all the electronic gizmo's and what not's. It irriates me to no end to plug in an iron, and see the lights dim.
In the end there's really not a lot that can be done, because even if you specified 180va per duplex, there are appliances other than gizmos that can soak up the better part of a 15 or 20A BC. Like, this 1500va space heater sitting in my bedroom. One of those can ruin your entire day. What else can be done? Design yet another plug format for 1.5A or less appliances?
My personal opinion, primarily as a consumer of these things, is that until there are design requirements in the NEC -- like my personal peeve, requiring a dedicated "electronic junk" outlet for bedrooms -- light dimming and whatnot is going to be a problem. I've posted about the power requirements for my bedroom when "all on" and it's non-trivial. (Oh, and now that I've fixed my DigiSnap (I had a hunch what was wrong because I remembered when it stopped working ...) I can get a better idea how much the junk in my room is actually using
