I have a quick question about subpanels:
Is there a limit to the number of subpanels you can have in a house? We are working on a very large home with three very distinct floors.
The owner would like to have a main distribution panel in his mechanical room on the bottom floor that did nothing but feed 4 other subpanels. I guess in a sense, its just like an I line panel you find in a more commercial application. Has anybody ever installed an electrical application like this? The owner would like this main distribution panel in the mechanical room and would also included a 60 amp subpanel that would feed all the mechanical applications for his house. This 60-amp sub would be tied into a generator transfer switch so he could keep all the vital systems of his house on line incase of electrical failure. I think he wants to put a few vital branch ckts from through out the house on here as well. The other three panels would feed each separate floor. Can anybody see any problems with this? There is the obvious things, like making sure the panel is rated for the amps feeding it, making sure the breakers all have the same short circuit rating, but if you have a main disconnect on the outside of house, and a main 200 amp breaker in the panel, is there a problem with a panel having three 100 amp main breakers and a 60? Thanks in advance, and if anybody has any better ideas, I would love to pass them on! Also, the feeder calculations for the entire house are under 200 amps.
