Working in the oil field we run across these fiberglass tanks which hold produced water. I understand there isn't any conductance in fiberglass. What it is we are needing to do is ground the fluid inside the tank to bleed off the generated static. I am looking for any common practices or suggestions on how to make this happen.
My thought is to put a water pipe clamp on all (3) piping entries at the bottom of the tank and tying them back to the ground grid. My thought is that any fluid in the bottom of the tanks would also sit inside the piping with the grounded pipe clamp. Thus grounding the fluid inside the tank.
