Okay... that's a wall-mount, plug-in unit. This type unit just gives a circuit rating and plug type. There may be an MCA and MOCP on the nameplate, but all I can glean from documentation is 20A circuit and NEMA 6-20R required.Thank you,
Can you help me out please? I do not see the MCA and MOCP.
This is the A/C here: http://www.ajmadison.com/cgi-bin/ajmadison/WY09D33.html.
Thanks
http://friedrich.gear.host/documents/wallmaster/WallMaster.pdf
You should be good as the "quickview" spec's on this page say 4.5A cooling, 4.3A heating.
BTW, this model is rated for 208V operation according to the "quickview" spec's... so you may want to rethink your current plan.
http://residential.friedrich.com/Products/ShowBrandDetails.aspx?AcBrandID=3
