Hello - I have a 7.5HP 3-ph motor PD blower with a on a soil vapor extraction system (pulling air out of the ground to treat contaminants). We're pulling a vacuum of around 4.5 in-Hg with air flow of around 185 scfm. The manufacturer of the treatment system originally assumed 230V service and spec'd a 30A thermo-mag breaker: but we're only running at 212V at the panel. The motor CB tripped after about 2 hours of operation. The manufacturer feels that the issue is that due to the low voltage, the system is requiring more amps.
This raises a question. In this application - basically unpredicable load (vacuum) on the motor, how does one properly select a high enough AMP CB without endagering the motor, or the panel?
Thanks!
- JJ
Thanks!
- JJ
