crossman
- Southeast Texas
engy said:Yup, but I am not sure it is a good application
A good application is whatever the customer wants.:wink:
But that's what the OP told us (finally) they want to happen:engy said:if the switch is left off, you don't have the auto-on advantage...
A manual override has to have something to override. It can either keep the lights on while while ignoring the motion sensors, or it can keep the lights off while ignoring the sensors.Hoyt said:Motion sensors are to really shut the lights off. Soooo...the switch left in the "on" position will allow the motion sensor to turn the lights on and off. The switch left in the "off" positon the sensors will not activate the lights.
See it is not that easy just when you think you have it someone points out the lights wont be automatic with the switch off. Back to the drawing board.engy said:Yup, but I am not sure it is a good application.
We are talking about a manual off scenario, like in a conference room where you want to force the lights off during a presentation.
I think in this application, just let the occ sensors do what they do... if the switch is left off, you don't have the auto-on advantage...
quogueelectric said:Back to the drawing board.
crossman said:A good application is whatever the customer wants.:wink:
What happens when someone shuts off the lights by the switch and someone wlks in there and the sensors are disabled and they slip and break thier neck who gets the pitbull lawyers attatched to thier buttocks?? Any takers? Hope you dont have a dba and a llc instead when this happens. Jury would be more sympathetic to poor firefighter trying to do thier job as electrician trying to cut corners does his own unsafe instalation because thats what the customer wanted. Good luck with that one.gar said:080529-1615 EST
It seems the statement of the problem has evolved to:
Use multiple motion sensors to automatically control contactors to control lights in a fire station on detection of motion and after an off delay time turn the lights off. The off delay is inherent in the motion sensors. Additionally provide a manual means to inhibit any turn on of the lights.
Why is the manual inhibit needed? And when and why would you enable the inhibit in this application?
crossman said:If the OP will describe exactly what he wants in detail, we will be able to accomplish it. Now, we may need a small PLC for the logic, but we can do it!
quogueelectric said:What happens when someone shuts off the lights by the switch and someone wlks in there and the sensors are disabled and they slip and break thier neck who gets the pitbull lawyers attatched to thier buttocks??
That would be my concern.crossman said:And what about using the sensors to turn the lights off? Isn't that just as dangerous as the lights not turning on automatically? Mechanic crawls under the truck to do some work, and the lights turn off a bit later, and he injures himself in the dark....
crossman said:Mechanic crawls under the truck to do some work, and the lights turn off a bit later, and he injures himself in the dark....
mivey said:How about a sticker above the switches that reads "Turn off lights when not in use". Treat them like big boys.
LarryFine said:Disclaimer: I never claimed that my solution (or the OP's request) was the safest or smartest way to do what he asked for, just the simplest.
