I believe you meant to say "cannot be more than 5' apart".How far apart are the existing supports?
For 1-1/4" to 2" the supports cannot be less than 5' apart.
From a design standpoint, you should try to get your anchors in horizontally. The 1/4" platic anchors would have held forever if the weight wasn't pulling straight down.
I'd use something like this on the conduits and simply anchor them with 1/4" plastic anchors.
For those who suggest Zamacs, if you are talking about the drive pin style anchors, I hate you. Everything has to come off at some point. Screws are our friends.![]()
It seems like a waste of time and effort to hang strut and then hang the conduit on the strut.
Is it an electrical or plumbing hanger?
The Zamac's I use and am familiar with (Hammer-Screw) are removable... the spec' sheet includes instructions for removal: http://www.powers.com/pdfs/mechanical/02843.pdf....
In that case every strap would be a violation.
I don't see why you can't leave them loose-- just don't tighten them down. Couldn't you just use a strap one size larger.
When was the last time you saw someone use those straps on PVC electrical conduit? I've seen the plumbers use them on copper pipe.
From a design standpoint, you should try to get your anchors in horizontally. The 1/4" platic anchors would have held forever if the weight wasn't pulling straight down...
Today I reattached the PVC conduit using the Caddy Straps. It worked out great and I have no doubt that this will not pull out like the original install.
How does that device allow for expansion and contraction? It squeezes the pipe just like a standard clamp just happens to have a more cushioned grip. I see similar devices for refrigeration or other lines that have natural vibration and it helps prevent transmission of the vibration.
Original install likely failed at least partly because of lack of expansion capabilities.
With hanger straps like in the photo use a locking nut and leave the clamp slightly loose and the raceway can move when expanding.
I've used them before in a very humid dairy barn where the temperature varied a lot. The kind I used were from T&B, my electrical supply house was able to get them. I think I bought the 1 1/8 OD straps for 3/4 and they fit perfect. Just snug enough so the pipe couldn't wiggle but just loose enough it could slide back/forth through the strap.
When I was trying to find them, I believe McMaster Carr had a whole bunch of different types too, zinc, stainless steel, etc.
i dont think those are code, it says for cpvc which is plumbing pipe not
elec pvc ....
Why would this matter?
Wouldn't bailing twine work just as well for support as anything that could be bought in an electrical supply house?
Why would the supporting means need to say it is for electrical PVC?
