What is happening is you are injecting the gas into your air intake. The gas is very explosive and when it is combusted you are completing the burn, not wasting fuel and leaving carbon deposits in your engine. My father has been an engine builder for over 35 years and owns his own shop. Putting an engine on his dyno will give you your hp and torque. Both improve very very slightly. On a side note I can take a white rag and wipe my tail pipe and find no black soot, it comes out just as white. The generator is not a solution, but it is a step in the right direction. Also, it depends on how it's built. Mine produces 2 liters a minute and works well on a small v6. Our test engine consisted of a Chevy 350 small block with about 85,000 miles on it. It was run on the floor for about 40 hours running with a generator. The engine was torn down and inspected only to find nothing! No excessive heat marks or excessive wear on bearings or on the cylinder walls. After these tests I decided to use my car as a real life test subject knowing if any engine trouble occurs my father would fix it. After about 1,200 miles, no problems. I used my fathers scanner for about the first 500 miles, one of the features is mpg. With the unit off I was getting 24mpg highway and with the unit on I was getting 31mpg highway. I do a lot of highway driving and always have and always will use cruise control, which I set at 73 mph, so I'm not feathering anything. As far as the alternator I can turn every possible thing on while on cruise control then turn them all off at once and not notice strain on the engine like when the a/c is on. Bottom line I get 30% better, I don't really care who believes me or not. It is fact. I'm not trying to sell these so I really don't care, I'm just an electrician and sick of high fuel prices. It saves me about a dollar a gallon so I am happy.
