- Windsor, CO NEC: 2023
- Hospital Master Electrician
It will still drain your batteries to a useless level overnight if you forget to turn it off. there is an attachment for the frig plug that will shut it off if the voltage drops below 10 volts. that's still enough to start your truckTruckers use 4 batteries and can run them 12 volt frigs no problem.Flying J sells them.
Most inverters will auto shut down at 10 volt's anyway.Woofy: It will still drain your batteries to a useless level overnight if you forget to turn it off. there is an attachment for the frig plug that will shut it off if the voltage drops below 10 volts.
What's a ballpark price on those, Wayne, do you know?You will need a current limiter/voltage regulator which can be purchased at most RV supply centers.
