I have pix too
electricmanscott
Boston, MA
Massachusetts Master Electrician, one man show.
Why do I think I will regret this....:grin:
iwire said:
I can't believe you placed the breaker for the sub panel so far down the buss.
What a hack. :grin: :wink:
There are probably a few things that I thought would come up. That is one. :wink:
"Warning! Warning!
Wire nut in panel!
Warning! Warning!"​
:grin:
In the right-hand panel, is there a neutral jumper between the two bars on each side of the panel?
What's the significance of 99? :wink:
What is the size of the re-identified black conductors being used for a neutral and EGC
Roger
Can't see it, but is the neutral bar in the left-side panel bonded?
Edit to add:
Gotta love that original panel... some breakers not used, others doubled up! How many different brands are in there?
Edit to add:
Neutral in left panel is not bonded to the enclosure.
The old panels did not have any unused breakers. Those are left from the circuits I demoed from the remodel
The "99" signifies the Great Gretzky special edition panel.
Rabitt ears are pretty much the way the 25 year old wire was formed. To stiff to undo.
Wire sizes are whatever they are supposed to be. :grin: Actually I think they are #3cu.
480sparky said:
How did you get them out of the original panel?
Took some workin' Strightened them out somewhat but they did not want to go the way I wanted do I just reformed the way they were.
cowboyjwc said:
Man you guys would make lousy inspectors. The covers are missing...duh.
No, they're there. It's just they were developed during the Reagan years...you know... SDI stealth stuff.
