- Massachusetts
infinity said:My guess is that those two bullet holes probably violate the minimum conductor bending radius.
What code section would you site?
I don't think there is one.
LarryFine said:Are you picking on me again?
fww56 said:Was it a major remodel or an addition that triggered the Arc-Fault breakers?
One question. The bottom right breaker in the sub panel, the red conductor appears to be one leg of a multi-wire circuit on a single pole Arc-Fault, or is it just an extension of a short conductor? The first thing I look for when I see a red conductor in a panel with romex is the phasing of the legs.
peter d said:UH OH! IS THAT A PIECE OF #6 TAPED GREEN THAT I SEE???? OH NO YOU DIDN'T!!
hardworkingstiff said:Looks like the service conductors have to go farther in the reworked picture. I guess your wire stretcher actually works? :smile:
Seriously though, how did you make it the farther distance? It doesn't look like you moved the panel up that far, so ???
iwire said:What code section would you site?
