kwired
Electron manager
- NE Nebraska
- EC
True an individual compressor can be used in more then one different machine, but the nameplate on an individual machine is the rating for that machine.My point is back in the 'old days' it was common to charge a unit to FLA. It was also common to see a lot of compressors with burned windings. Units were super no efficiency and tripping overloads were common. Compressor manufacturers were seeing too many compressors failing in the first year. (their warranty period) Switching to RLA decreased the rating of the compressor but also prolonged the life of the compressor.
While you are correct that some compressors are rated in btu's many are designed to use multiple refrigerants and operate at different pressures and btu's.
AFAIK charging according to amps pulled is a poor method, the way it should be done is to determine superheat and charge accordingly.
