Here it's very common to remove the plaster without removing the lathe and sheetrock right over it. I've also done jobs where nothing was removed and they sheetrocked right over the lath and plaster. It was nice because I could make holes in the old wall wherever I needed them.220/221 said:I'd find a way to make them remove the wood lathe, then I'd deal with the other issues.
Yes, exactly.peter d said:It was nice because I could make holes in the old wall wherever I needed them.![]()
al hildenbrand said:Lots of box extensions in those jobs.
iwire said:Next your gona tell me you run NM to this box.....![]()
peter d said:I know, it should have been RMC and an FS box, right?![]()
So my shorthand doesn't add any confusion, here is the full text for that section of the table:al hildenbrand said:I see a definition of groove. :roll:
Drywall over lathe on studs is drywall over a carpenter assembled grooved surface. Take out a lathe, or a couple lathe, and the surface is still grooved. Some of the grooves just got wider.
I'll bet this Table E3702.1 has absolutely no requirement that the 0.0625 inch steel plate or sleeve extend over all the groove, 'cause the groove's got nothing to do with the physical protection of the NM-B.
Here, think of a sleeve. An EMT sleeve. If the studs are firred out so a stud face mounted run of EMT can be covered by drywall without bulges, do we think the stud has to be grooved and the EMT set inside the groove for the wires inside the EMT to be physically protected?
The break in the firring is the groove.
r_merc said:Letting Romex rest on the sheet metal is asking for trouble in the future (1 yr, 5yrs,30 yrs +).
peter d said:Yes, because that's so much different than NM cable being clamped into a 2-screw die cast connector, right? :roll:
This is what I think Al was referring to.mivey said:for the full length of the groove in which the cable or raceway is installed."
iwire said:Or the same NM resting on the much smaller metal staple.
peter d said:Or the clamps inside a metal old work box...we could go on and on...
stickboy1375 said:Thats exactly why I dont use metal boxes with NM...![]()
peter d said:Yes, that's extremely dangerous...![]()
stickboy1375 said:This makes it super duper safe.
MLO? Where are those grounds wires going?stickboy1375 said:I know, I also only use these on my panels...![]()
mivey said:[edit: {gasp} metal staples]
A number of the jobs that I've done that have been rock over plaster have had a number of existing openings that remain and are extended to the new wall surface.peter d said:Quite labor intensive, and it would have been a great application for the adjust-a-box.
