crossman
- Southeast Texas
Re: inductive vs resistive loads
I do have The American Electrician's Handbook and the Rosenburg Electric Motor Repair.
I also looked at several sites on the net... and a typical comment from the books and the sites is this:
"Low voltage will result in the motor drawing higher current to deliver the same horsepower " (italics are mine)
Okay, well and good, I agree. But what kind of driven load would keep a constant horsepower load on a motor as it slows down due to low voltage?
Would a fan? Seems to me that lower voltage would result in more slip = lower RPM and less horsepower output, not a higher current draw.
Now perhaps I am being asinine, but what about the case where the voltage = zero? Hmm... lower voltage causes a higher current?
Obviously there is more to the situation than a blanket statement that says "if you lower the voltage, the current will increase."
This is sort of like saying "electricity always takes the least resistive path to ground."
