Re: inductive vs resistive loads
Sorry I had to walk away.
Speed Torque curves are used to show you that when you turn on the motor there is very little torque, you need to get some RPM's going and current induced into the rotor which will then induce a CEMF. This CEMF will then bring down the current.
The normal operating speed range of an induction motor is around 75 to 95% rated speed (can not turn at synchronous speed). You notice that the peak of the torque curve is just around or below 75%, because what this means is as you add load to a motor it will slow down, thereby affecting the torque applied and the current drawn. Once you get to the low side of this peak, the motor will stall because as is shown, the torque now drops off even as the current raises. (Note these curves are design curves that are used for picking out a motor to use on a certain load. Nothing is taken into consideration for changing voltage.)
There are other design motors that have different speed torque characteristics to give you better starting torque and a lower pull out torque.
Pull out torque, (breakdown torque) is that tip of the curve where the motor stalls.
