M. D.
As you may have heard ,..here in the Northeast we have had some power outages , lasting several days.. I rigged up for a customer of mine a way so she could run her boiler , I would like to run it by the good folks here to get some feed back....
I installed an inlet on her boiler . 15 amp 125 volt straight blade,. mounted in a 4" square box the grounded connection and the grounding are connected to both the house panel via my connection to the boiler circuitry ,. and to the very fancy portable generator via a hydra cord which came with the generator .
The hydra cord is a multi-outlet extension cord 12 awg. I then replaced the single pole switch on the boiler with a 3 way ,.. the common feeds the boiler ,.. I then took the normal house line to one of the runner terminals and the hot from the inlet to the other ,.. then I installed it so that up is normal house line "on" and down is generator / off .. the only time the inlet is live is when a live extension cord is plugged into it . the boiler is gas with two very small .6 amp circulators .
It took about an hour to install and I thought it was pretty clever , the only thing that concerns me is the grounded and grounding connection ,..but I have installed gentrans which share that connection ,..I don't think there is an issue.. what do you folks think .. as always my protocol included shutting the main off any time a generator is employed ..
