Have any commercial guys had problems with their temp poles that are set next to a trany. In Durham they turned down a job because the contractor installed a standard temp pole with 10kva breakers, The trany was 50,000 or so. Cost a bundle to correct
You can "play" with the Mike's Calculator you posted and find that it won't take too long a run of 100 amp cable to take that 50000 down to a more manageable 22k and those breakers should be readily available.
