Installation Questions
anbm
TX
Designer
Guys, I have (2) questions need help:
1. Does electrical ground bar have to be installed inside electrical room? If not, are there any restriction from NEC?
2. If not inside electrical rooms, is there a spacing requirement between electrical conduit and duct work, other piping?
Thanks!
Thanks!
A separate ground bar, in the electrical room, is a design issue not an NEC requirement for general installations.
Clarification: I am talking about dedicated / separate ground bar for grounding / bonding purpose.
Do you mean an intersystem bond as in 250.94?
Is the op thinking of a "quiet" ground?
What's a quiet ground? I've never heard of it. (Pun intended!
