Installing Flood Lights under eve?
SSpiro
Tampa, FL
I have three Rab floodlights I'd like to install under an eve that is made of aluminum material.
What is the best way to install? Use an old work ceiling box recessed into the soffit? Use an outdoor surface mounted box? If so, how would it fasten to the aluminum and not sag?
Any input would be great.. Thanks!
SSpiro,
Do you normally do electrical work or just distribution ?
I'd use a surface-mount box and find a rafter tail above the soffit.
I've never run wire through the eve before.. will I have any issues, you think, running nmb straight down the eve from one fixture to the next? Or will I have issues with rafter tails..
SSpiro,
Just electrical work for myself, not for others. I only do what's within my capabilities, which isn't much. I've added new circuits before to my panel, upgraded fixtures/recepts/switches, etc.. but thats about it. One of my best friends is a licensed electrician, so he's usually on hand whenever I venture out into a new project.
I've never run wire through the eve before.. will I have any issues, you think, running nmb straight down the eve from one fixture to the next? Or will I have issues with rafter tails.......
Depends on how the structure is framed. Usually, there's a chase all the way across. But not always.
Oh lovely:roll:
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician, then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
