mivey
No. I have no doubt it can read phanton voltage. With a typical multi-megaohm input you can get that. What you need is a lower impedance to be able to distinguish between phantom and leakage voltage.Well are you saying that the meter won't read phantom voltage? Because if that is what you are saying then I disagree because I energized the black wire on a piece of nm cable and left everything else disconnected and I read 38 or so V from the bare wire to a grounded box. I repeated this at home with a 3' piece of nm and it read the voltage
