gar
- Ann Arbor, Michigan
- EE
150318-2337 EDT
Electric-Light:
I don't believe that Lutron explicitly defines what a CL dimmer is. but from their description one would be led to believe a better electronic control is used and that might imply the need for power for the electronics other than what is available from the series connection with the load, and that would require a neutral connection.
If there is no neutral, then to derive power for the electronics it is necessary to have some portion of the half cycle non-conductive (thus full brightness is not possible), or a current transformer is required to obtain energy from the load current.
Since you have close contact with many different Lutron devices I will then assume from your comment that there is no specific indication from general Lutron descriptions that a particular type requires a neutral. However, I believe that if you want a good dimmer, then there should be a neutral connection.
My comment on a magnetic dimmer was that it needs to produce very little average DC current. This can be accomplished with either a forward or reverse phase control. That Luttron does not make a reverse magnetic dimmer is not important to understanding what is the primary requirement for dimming via a controller on either the primary or secondary side of a transformer.
Incandescent loads are resistors that convert heat to light, and any way you can adjust the heat will determine the light output. No heat no light. Full heat full light. There are no electronics in an incandescent light, thus no special characteristics. No minimum voltage, no minimum current, no threshold points, no special requirements for phase information, and there is no disruption of the dimmer control because of the turn off phase point (it is the same as the voltage zero crossing).
The easier control of an incandescent is not because of its larger power requirement. I can phase shift control the brightness of a 757 pilot light as well as a 100 or 100,000 W bulb.
If one can obtain a basic understanding on how a particular dimmer functions, and the same for the loads being controlled, then one has a greater chance of putting together a successful system. We need basic knowledge, not just use A with B. We need to know why.
Electric-Light:
