ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
I'm absolutely sure of it.
To be clear, I'm not talking about different nominal grid voltages, e.g. the spec current at 208V vs. 240V. I'm talking about what happens when the grid voltage fluctuates higher than nominal, e.g. you're measuring 247.6V on a nominal 240V service. An inverter with max output of, say, 32A, will still output 32A at the higher voltage and thus output a few percentage points more power.
That's at least not universally true. I remember seeing the specs for some inverters that specified a voltage range and a maximum current range (high, low, and nominal) where the low end of the current range corresponded to the high end of the voltage range and vice versa, and the IV product was always the same. They were central inverters, if that makes any difference.
