Bmw318be
- S Republic
Hi
Hi
without knowing the control loop configuration and seeing the code it's next to impossible to determine the issue
Ans: i would check this as my equipment is the pump
what position the actuator? it goes to a predetermined position (100%) when the pump runs?
It goes to predetermined location, for feedback and command also matched in scada monitor.
It drifted forward and backward if capacitor was not installed in the loop end before actuator board input
but if the actuator is at a commanded position and the feedback does not match/change I would start looking at the feedback sensor/code
Hi
