jim dungar said:Rattus,
The consistency I am looking for has to do with the methodology of solving networks, regardless the point of reference. The base formulae should not change if the reference point is chosen as L1 or L2 instead of N. So if two voltage sources are in series the resultant voltage is the summation of the two individual sources even if it means having to add a negative value. With this basic concept it is much easier to be consistent with the application of Kirchoff's Law for solving 120/240V multi-wire and 2-wire combination circuits.
Sure Jim,
You can simply add the magnitudes in a 3-wire ckt to obtain V12. The phase angle is unimportant here. But how would you compute line voltages and phase angles in a 3-ph wye? There is probably a formula for that somewhere.
But, somewhere in the derivation of that formula, subtraction is involved. It is fundamental that a voltage difference is obtained by subtracting one voltage from another! Of course we use a common reference point, and the neutral is the logical reference point. I would never use any other point if a neutral is available.
I think the crux of this matter is that most in the trade use formulas, and that is OK, but the more general approach is to use phasors, and this is not a trivial endeavor. In a sense, you must derive your own formulas.
