bbeell@live.com
- california
The neutral wire runs without change from the book view
The neutral wire runs without change from the book view. it just runs separate from its cable. it is still spliced
to the cans, but now its past banished cable companions don't have to travel to the cans with it, less splicing,
less work.
The one wire explanation: on each three way switch' not the two traveler wires, but the one wire remaining.
not part of a cable, its a single wire (one wire only).
Time and work are saved because' The neutral still has to route and splice into the four fixtures, but since
the neutral is no longer part of the previous 12/3 cable, the other two wires (travelers) don't have to route
and splice into the four fixture wires.
How is the neutral ran?
What exactly do you mean by "one wire only"? You cannot just run a single hot conductor by itself.
less work.
