Poweranytime
FL EC
- Nature coast Fl
- Master EC
I'm not an inspector but in a residential storage area got to have clad, pipe or sleeve to make an effort to protect
How high the building was removed from the code a while back. NEC 334-10 Types of building still matter 334-12Yes it is residential only three stories or less
Sent from my SM-G986U using Tapatalk
You're showing your age.
I had a 73 Datsun 240z two seater it was a lot of fun to drive...but what a rust bucket.
Just cover with wire mold, I would use metal one not plastic though.
Is 'could be' similar to 'possibly be' or 'likely to be'?... could be cracked....
I don’t believe the “subject to damage” would come up for this install under the basement floor any more than any other direct buried installation.My help was investigating a fault in cable that appears to be direct buried under the basement floor. Subject to damage?
I'd like to string the guy up that didn't sleeve it.
Power ball and similar games not likely to win the top prize.Is 'could be' similar to 'possibly be' or 'likely to be'?
To differentiate between these terms I use buying a lottery ticket as an example.
If you buy a ticket it is possible you will win, however it is not likely.
