Actually... we can.
You can join us if you wish, but it appears you wish to be excluded. Your choice. Don't say we didn't try.![]()
I choose understanding
not making things fit my lack there of
enjoy your 'alternative facts'
:lol:
Actually... we can.
Well if you choose understanding over not I would think you'd be more open-minded. Apparently not and contradictions abound...I choose understanding
:lol:
Well if you choose understanding over not I would think you'd be more open-minded. Apparently not and contradictions abound...![]()
Great. So far we have two conventions:every text I've ever seen: Ia + Ib + Ic = In
Every textbook Ingenieur has ever seen: Ia + Ib + Ic = In
Several posters here: Ia + Ib + Ic + In = 0.
Both are valid conventions. Either choice may be made, and the resulting physics is the same. All that differs is the mathematical representation, as far as the sign of In.
Ingenieur, if you have never seen the second convention before, consider this an opportunity to broaden your horizons.
Cheers, Wayne
Exactly, that is the convention under which Ia + Ib + Ic + In = 0 is the statement of Kirchoff's current law. Which is the convention Smart$ used in the spreadsheet in the OP. And the numbers in the OP satisfy Ia + Ib + Ic + In = 0 (up to a decimal place). So what's the problem? What would you change in the OP's numbers?into node +, out of node -, that is convention
Cheers, Wayne
These two statements are in contradiction. If you choose the convention in your first statement, then KCL is Ia + Ib + Ic + In = 0. That's the mathematics.KCL Ia + Ib + Ic - In = 0
are you serious?These two statements are in contradiction. If you choose the convention in your first statement, then KCL is Ia + Ib + Ic + In = 0. That's the mathematics.
Cheers, Wayne
You still have a sign error, see the example in my last post.Summing at the node
Iabc + entering
In - leaving
summing
Ia + Ib + Ic + (-In) = 0
or Ia + Ib + Ic = In
How about wikipedia? https://en.wikipedia.org/wiki/Kirchhoff's_circuit_lawsone text, just one
Then you have been exposed to a limited range of texts. I'm telling you they are stated both ways.every text I've ever seen: Ia + Ib + Ic = In
Absolutely.:thumbsup:So once again, my calculator's magnitude and angle are correct.
I may see if I can post a few so it may help him expand his knowledge.Ingenieur, if you have never seen the second convention before, consider this an opportunity to broaden your horizons.
Cheers, Wayne
you are just making stuff up nowThen you have been exposed to a limited range of texts. I'm telling you they are stated both ways.
The shorthand is what is confusing you. If we use a sending/receiving convention we get
INsr + IAsr + IBsr + ICsr = 0
If you mix sending and receiving you can get:
INrs = IAsr + IBsr + ICsr
The shorthand notation is making you incorrectly conclude that IN should always mean INrs but that is simply wrong.
You are in error.
So we go from EVERY textbook to a EE power textbook? Already backing up/hedging your bets? How amusing.that is what you need to do
a page out of an ee power textbook
it is not my knowledge base that needs expansion
let the reader decide
simple
So, the way I've been reading this, and perhaps others too, is that currents into the node have positive values and currents out of the node have negative values. That convention yields Ia + Ib + Ic + In = 0.into node +, out of node -, that is convention
If you really think that is what Smart$ has calculated then you are not getting it.Wrong
60 - 92 = 32 ???
