electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
It will have, just not done yet.You got a tile bathroom with a tub and no pooper?
We had an outhouse at a lady’s house where we stayed often.It will have, just not done yet.
I kinda prefer it honestly. No concern about clogging, making a mess, less cleaning, lower stress IMO. Some mice live under mine, and poke there heads in now and then.........We had an outhouse at a lady’s house where we stayed often.
Hated it.. it was either cold, or you worried about what was in it. Never got stung on the derrière, but was always scared of the wasps in the outhouse. It was a constant battle to keep them out.
Did get stung on the head, neck are a few times Opening the door.
Yeah, solar does seem like snake oil to me. It might be a bias, based on that one smooth dude I met at the HD. A sample size of one is not reliable.Why reinvent the wheel when PV Watts is more accurate and reliable and conservative enough to base an investment decision on? Just sayin.
It's a little unclear to me what exactly you're trying to say about salespeople, but here's my two cents:
First, putting solar panels flush to the north side of a house may or may not be cost-effective in any given situation. It should not be dismissed out of hand as snake oil salesmanship. I've seen some northside installs that I definitely thought were suspect. I've also installed panels for people on north (more often northeast or northwest) facing roofs when it was plenty cost-effective for them. We've also tilted them back to the south plenty of times, but sometimes aesthetic or cost reasons (engineering) make that not the best choice. Every project deserves its own consideration of the factors involved.
Second, there are surely some dishonest or unknowledgable salespeople in the solar industry, as there are in any industry. But I hope your comments are not intended to refer to the whole industry, which also has plenty of honest and well meaning people and companies.
Anyway, the average US house takes a kw of power so this is 8800 kWh of energy per year.
I guess a "quality factor" for panels would be, What percent of this total can be supplied by panels?
Um. . .I think I'll go back and look for that HD guy. . .My system makes 19,000 KWH per year.
How much does your PoCo want for a kWh? Ours does about $0.15 per.
From the shadow your panels are facing south, yes?
It sure where your from, but the states with the most solar offer the best subsidies and incentives. That’s the only reason places like Cali and others are booming in solar.This back-and-forth is bringing up mental reservations for me that I didn't know I had.
Generally, more complexity = higher failure rate, but I know better than to ask makers for their MTBF data.
So, I'm skittish about signing contracts with powerful orgs that can afford lobbyists and I'm skittish about the hidden costs of ownership.
We have two layers of shingles on our roof so it'll be a while B4 we need roof work, but you guys have given me some questions to ask and things to think about, if I ever want to pull the trigger on one of these.
Thanks for your input.![]()
I think our power here is around 12 cents.Um. . .I think I'll go back and look for that HD guy. . .
So, did you wrap a building around the solar install or put solar on the building? It looks like it could have been either. Like the A-10 "Warthog", they took a rotary cannon and wrapped a plane around it instead of shoehorning the gun into an existing platform.I think our power here is around 12 cents.
My building was built with the solar in mind so yes it's ideally oriented, 36 degree tilt.
IMO if you have the space, building something like I did is the way to go. That whole building with solar system cost far less than it would have cost to put in a " regular" PV system ( not counting my time which is kinda hard to equate to dollars).
That’s got to be the smallest wire I’ve ever seen in a 200 amp elbow...It is stick built, factory made trusses, and the panels mounted directly on the trusses. There is a system of flashings and gutters to keep the rain out. There are more details in this thread:
My solar system
I have alluded to this in various prior posts, but I thought I would post some pictures and mention some of the creative aspects of it. Ive had this idea brewing for years about building a structure and having the modules be the roof. It just seemed like such a waste to have two roofs! So...forums.mikeholt.com
NC had awesome subsidies until they let the state incentives expire and didn’t renew them.
Our solar has slowed WAY down.
Some people used to say $10 per hour, some say half their wage.not counting my time which is kinda hard to equate to dollars).
I think the two things that matter is if you have the skills, and you WANT to do it. Regarding the former, I once questioned on this forum a year or so ago why more of you don't put a solar system on your house. You have the skills essentially (yeah PV has a few unique things about it but not rocket science for an experienced electrician).Some people used to say $10 per hour, some say half their wage.
A coin flip decides if you will do it yourself or pay your neighbor.
What amount of dollars per hour would it take for you to be completely indifferent as to which way the coin landed?
This method thanks to D.V. Lindley, the Brit who wrote about Decision Making.
You may be surprised at your own answer. If you ask others who know you, you may be surprised at their answers. Both how much you should paid vs. how much they should be paid.
Just compensation: When I ask a mortgage company to reimburse me a "reasonable sum" for my registered letter plus time and aggravation because they double or triple bill me, they strangely fall silent.
The same silence if I ask them for a sworn statement by a company principal confirming, denying or explaining their conduct.
