Around here there are many old fixtures hanging from special threaded fittings that cap off the
Existing gas pipe and provide a thread and an opening on the other end to mount a ceiling fixture.
They usually are K&t with a switched neutral. Deep canopy tulips bell conceals the gas-pipe My question is what is your recommended procedure for swapping out an obsolete fixture? Cost effective replacement for a functioning, albeit inadequate electrically, lighting $&outlet.
The existing light & switch work.
Renter wants to spruce it up with a new $75 fixture
1. Run a new home run to a new Afci breaker in a new panel that will accept the Afci cb
1a. Fish new Romex or mc down to the switch
1b. Have a plumber disable and cut out the old pressurized gas that occupies the center of the room
1c. Create new structure in ceiling to support fixture less than 35#s
Or
2. Decline the work
Or???
Thanks guys!
Or
2. Decline the work
Or???
Thanks guys!
